ahh quick wiring question....
Orio5
ok my brother has a 15"kicker L5 and its a dvc 2ohms and he got this amp > http://www.sonicelectronix.com/item_8515.html and i want to know if i can just leave it at 2ohms you know like wire one + terminal from the sub to one on the amp and the second + to the other in the amp...and one - from the sub to one on the amp and the other - to the amp ..since the amp has 2 sets of terminals like the sub...idk im confuse someone help me //content.invisioncic.com/y282845/emoticons/help.gif.cee8f684da1ba626487a8bc51152e1ec.gif
the amp has two sets of speaker outputs yes but it is still only a single channel amp. That is only there for convience of hooking up two subs to it. You would only use one side or the other .. not both for a single sub. You need to wire it to a 4ohm load and just hook it up to one of the outputs.
prolly **** something up. Its used like this. Lets say you have a 4 ohm SVC sub.. ok you just hook it up to one output and you are done. Ok later down the road you get another 4 ohm SVC sub. All you have to do is plug that into the 2nd output and bam you now have a 2ohm load shared between the subs.
Orio5
Orio5
Belvidere, IL.
DaveDSMer
