then go with the 4 channel amp and RCA y splitter option. it makes your one RCA output into two.Yes but then my I wouldn't have rear sound right? And the Kenwood are 2ohm speakers
Sent from my HUAWEI Y536A1 using Tapatalk
Yes, but you will gain distortion and eq problems.Could I use high level inputs instead until I upgrade head units that way I can still set fade and balance?
If your using the high level its because you have a stock headunit.I rarely turn up my volume past 20 (goes to 56) so if I have everything tuned right distortion shouldn't be an issue right?
Get this Amazon.com : PAC SNI-35 Variable LOC Line Out Converter : Power Converters : Car ElectronicsCould I use high level inputs instead until I upgrade head units that way I can still set fade and balance?
Honestly its not that far off from a stock head unit at all nowadays.In using a JVC KDS88BT headunit deffinatley not stock lol
20x4 watts.In using a JVC KDS88BT headunit deffinatley not stock lol
