T THXdts 10+ year member CarAudio.com Elite 1,522 0 Maryland Jul 13, 2007 #1 Once you put them in your box and glue them, you can only use them once? Because you won't be able to get the pvc glue off correct? Click to read more...
iagrdshaka 5,000+ posts Down with jimmy hats 20,280 122 Midwest Jul 13, 2007 #2 Once you put them in your box and glue them, you can only use them once? Because you won't be able to get the pvc glue off correct? Click to expand... Use duct tape not glue. Problem solved. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
bikinpunk 10+ year member G-g-g-g-g-unity! 3,274 1 Alabama Jul 13, 2007 #3 Use duct tape not glue. Problem solved. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Click to expand... x2. Works very well, and isn't permanent. Just remember to use silicone around the outside where the port is mounted to the box to protect against any leaks.
