aeroports vs slot port
thats a desgin someone made for me already but i am not sure what the dimensions are but thats how i need the box to look
and i want each sub to have 3-3.25 after displacement of everything and tuned at 33hz
ok it will be in a truck inbetween the rear bucket seats and inbetween the back wall and the front console so thethe wide is the distance between the seats that needs to be only 17.5max the lenght is the distance from the back wall to the front console max of 26inches and the depth would be from the very top of the box by the roof to the bottom of the box and i was planning on mounting the subs on the top of the box by the roof
i hope that helped
and the length and width has to be that size and the depth can be w/e as long as after subs and port displacement each sub has a net cuft of 3-3.25
do you understand what i mean now
ahh, makes much more sense now. give me a minute.
Dimensions of that box-
17.5Wx30Hx26D
Nearly 3ft^3 per sub. Like 5.8 total.
ok to get 6-6.5 after displacement for the subs and the aeroports which are 2 of them 6inches that are 18.14inches long
what would the depth be
external / internal
29" / 27.5" tall
17.5" / 16" wide
26" / 24.5" deep
using the 18.14" flared aero ports, this would give you ~6^3ft @ 33hz.
edit: you also dont need to account for woofer displacement as kicker includes it in their recommended volume.
ok and one more question just for further help what website or formula did you use to figure that out and also how did you figure out how much airspace each aeroport takes up
so should i have each sub at 3cuft or more or less kicker remcommends from 1.75-3.25
i already told you how you figure out how much air space an aeroport takes up. did you even read my post?
you dont worry about the flares since they wont make much difference. you get the area of the 6" port which is going to be 28.27 and multiply it by the length of the port. then you divide by 1728
i would just use 3 cubes, like bucky boy and i made. should get down, although i dont really like the orientation of the box in the truck. as for what website i used...i use my own tutorial that i made a couple years back after having the old timers teach me....its in my sig, next to the red part of the Ethiopian flag in my signature.
ok sorry completely forgot you already told me that
and what else can i do for subs w/o that box in the truck
i hve a 01 f150 king ranch with bucket seats all four and 2 center conosles with no room behind or under seats
only way i could do behind seat is do a 2 inch seat lift and a 2inch forward seat move and pull the back panel off the wall and cut part of the back wall that sticks out and i could get 4 12's back there like i seen a guy do on f150online.com
what else would you suggest for subs
honestly, if you dont have the room to go behind the seats, i cant see too much wrong with what you plan on doing.
i would try to get a hold of tommyk90 and ngsm13 to see if maybe you could get better performance, by maybe doing a side firing or up firing port. i know ngsm has experience with the upfiring port and tommyk with the side firing. try to see if you can get an idea of whats best based on what they tell you.
slot port or aeroports and if you dont mind i would really appreciate you asking them bc i dont kno how to find their profile and you kno way more about this stuff than i do
i am like in a jungle with this
Like I said before king, once you get everything how you want it just let me know and I will be happy to make you another design. I'm sure you can understand my frustration from designing the boxes and then you changing something.
Your setup should sound great.
ok well the first guy tommy i think u recommend me to said 4.5net for both subs
and bucky send me a pm wih the price for a box like that with carpet and just a estimated price
and also how much does shipping run
king ranch
Banned
king ranch
fl
Boominator
