Aeroports from partsexpress?
make sure you tape them good, i just pulled my sub out and saw that two of the ports need to be retaped
more than likely they will start to sag and need to be re taped regardless what i have found works is to shoot some real small screws through the rings and into the port to hold it steady wrapped with some duct tape
Yeap. Metal screws work well:)
Best thing I found by far to hold them together is packing tape....clear packing tape. holds much better then duct tape, esepcially when it's hot out.
Everything you need is in that aero kit:)
A lil secret of mine is to use a lil mist of spray on glue (like some 3M super 77) to help hold the ports together and then tape them with electrical tape. It only take a mist. If you spray too much they won't want to come back apart.
scoob8000
scoob8000
Steelers Nation
roarzorz
