Aeroport dampening?
usualy port resonance happens at higher frequency then you would have to worry about in a subwoofer enclosure, the longer the port the lower the resonant frequency. if you input your enclosure parameters on winISD it will tell you the resonant frequency of the port. if for some reason the resonant frequency of the port is low enogh that your music is going to play in that range. you can build a brace around the port to to a wall to bring the port resonace to an even higher frequency.
You could try it and see if it made any true difference, but really in all actuality it might not make that big of a differene. Unless you are getting some serious port resonation....
You also get resonation harmonics which are simple multiples of the original freq.
MisterE
pimp your own **** ride.
MisterE
filthy nasty dirty south
joetama
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
