Aero ports
flared gives more efficiency while a round port is just a round port. Basically you need more port area per cubic feet when going with a regular round port compared to a flare. If you just want to do round ports, you can use pvc ports or even sonotubes if you need bigger then 6 inches. You can use a heat gun to add flares or with the sonotubes, fiberglass some flares.
I flared them about 3/4" wider than the diameter on each side of the pipe itself. Used a heat gun, water and metal bowl to make the flares. This helped me.... YouTube video "DIY flared ports PVC"
malandrin4o8
malandrin4o8
San Jose, Ca
Jes 42
