aero port or stick with slot port...?
paulie
i have one eD 13Ov.2 that i just recently got, loving the sub so far, but i had planned to build a ported box for it. i had a box designed, here it is....
it is 2 cubes tuned to 32Hz. i was just bored and thinking about doing an aero port for this box, cuz everyone seems to be doing slot ports, which i hear is just the cheap way to port. i was this box to sound good so i was thinking of getting a 4" port from partsexpress, 4" flared port. well i put that same box in BBP6, this time using 2 4" round ports, and it is showing that two 4" ports, 34" in length will tune it to 30.8Hz. does that length mean 34" per port, or is that 34" total port length, making each port 17"? the sub will be either facing up or on the side of the box facing the opposite rear fender, the port will be facing towards the rear of the trunk. is this design better or should i just stick with my slot port? is there any advantage using flared ports for just daily use? it would be cheaper to use PVC so would it be ok to do that?
I use both but feel I personally prefer precision ports. They cost more but 2 4" aeroports give a good size port area and no port noise. On my fiberglass boxes I found precision ports got higher numbers than the slotted counterparts. If money isnt an issue go round. If money is tight then slot it.
147.6 in stock one huh? nice going egg. Dont see you on the forums anymore.
you keep changing it //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif highest yet it 148.4:crap:
its back up with a new layout. Had a problem with the last forum.
in competition? because the 147 is the only one on the site for 06
paulie
paulie
Illinois
Skip01
