adulbich
The T series like adulbrich has weren't made for how we use them in the U.S. The same isn't true about the HD series.
You're not going to get rated power from any 10k board wired at 1 ohm. You can't compare a Korean amp at .5 to a Brazilian amp at 1 ohm, it doesn't work that way. The new Brazilian amps do not blow at full power either. They were not designed to run under 1 ohm and that's why they blow
If you haven't used a new Brazilian amp maybe you shouldn't comment on them without knowing what they do and don't do
Yes they can be compared. Korean amps can make rated power. Brazilian amps can't. Bottom line.
I have used several Banda amps. Yes I have plenty of experience with both Korean and Brazilian
You continue to boast about them and talk as if you have all these amps in your vehicle. You are a taramp dealer and benefit from trying to show how well they "work".
Just like my previous experience people mentioned how db drive has won records in the lanes, but are you gonna waste your time with cr4p soft parts and always blowing? Nope!
Same goes for taramp, no matter the new line or not they cannot handle vibrations, they cannot do rated to long (on the current clamped brazilians), they cannot be wired low.
Ive talked to 3 taramp distributors and some of the company techs who reside in brazil. They all have said even the new lines being made for US mainly are still not up to par with the original competition amps made in asia.
Sent from my draconis using Tapatalk
He is running Taramps amps
What an odd question. I never had the guys kicker amp. Why do you ask?
The Kicker thread, lol
****Update*****
I increased the subwoofer level on my headunit and decreased my amplifier gain. Now I can pull hairtricks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif)))))))))
I'll changed the settings during lunch and didn't have much time to shoot a video. The best hairtrick is with my friend christian who has long hair. He's a guy, lol. Gabby's hairtrick wasn't as good, but I'll include that just so there's a girl. It's a different girl than the Gabbie that some of you members know about //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I can probably get more videos tomorrow that are better. I had five minutes before class to do these, lol. I'll upload in a few minutes. Might take a while
I'm not sure where you're pulling this "brazilians don't do rated" crap from. You have absolutely no evidence to back it up other than failed clamps of the T20k which is an older amp that's completely irrelevant to the conversation.
I suppose the other guy who swapped from a Banda 7k to an AB 750.1 and lost 2db was wrong as well as everyone else who has had the same experience. Where are your clamps and SPL numbers before and after to back up your wildly misled claims?
There's only one good thing that comes out of brazil, and that would be there women.
^Thruth
In4the vids!
Thanks!
I swapped from the Banda 7k to a DD M4a. Both wired to one ohm.
Your 10k will not do 10k. Truth.
Come back with proof of your claim
We clamped 6300-6800 out of each American bass 750.1 amp starting at .5 not sure what rising to. It was on the new magnum term lab
I seen one Banda 7k and a few taramps at world finals... The rest were Koreans
^Thruth
Thanks!
So no meter scores? That means absolutely nothing then. You swapped amps, that's all that tells us.
Senchez and Chad Wilson are both proof of similar rated Brazilian amps absolutely destroying Koreans at higher impedances.
There's that .5 again. You can't compare apples to oranges.
And a large part of not seeing them at finals was the fact that db drag pretty much outlawed them. The magnum's clamp sensor wouldn't work correctly on some of them (funny because other SPL meters could clamp them just fine). And people are also used to using Korean amps. Just because something isn't as popular does not mean it does not perform. There is plenty of real world experience showing that both types of amps work great when used correctly.
Mitch86
Mitch86
Tennessee
adulbrich
