Adire Audio Brahma
Don't get too excited.....the Brahma has been downgraded some according to the last specs he posted. Tumult line will be the new "top dawg"
From a technical standpoint, they are "down-grading" it...but I wouldn't suspect it to be a lot "worse" //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
But yeah, excited to see the Tumult in all sizes, it'll be their top dog. Also heard Adire is focusing more on CarAudio!
NG
Here's some basic info. More will be following shortly (no, I won't specify an exact date):
Complete product lines:
Shiva. Two inch diameter voice coil, overhung design, 14.5mm one way Xmax. 10", 12", 15" sizes, dual 8s and dual 4s available. Basic entry level SQL sub, low cost, easy to use, good performer.
Tempest. 2.5 inch diameter voice coil, overhung design, 18.5mm one way Xmax. 10", 12", 15" sizes, dual 8s, dual 4s and dual 2s available. All around banger. Will play deep, good SQ, get loud, budget SQL weighted to more SPL than SQ.
Maelstrom. Three inch diameter voice coil, overhung design, 24mm one way Xmax. 12", 15", 18" sizes, dual 4s and dual 2s available. Monster big driver. Handle lots of power. Real SPL monster, high BL (29 N/A), high stroke, still retain some decent SQ.
Koda. Two inch diameter voice coil, XBL2 motor, 18.5mm one way Xmax. 10", 12", 15" sizes, dual 8s and dual 4s. Basic entry level SQL sub, low cost, easy to use, better SQ than the overhungs with output around the Tempests. Like the current Koda 10s.
Brahma. 2.5" diameter voice coil, XBL2 motor, 26mm one way Xmax. 10", 12", 15" sizes, dual 4s and dual 2s. midline SQL sub, competitive price, similar to the current Brahmas in SQ and SPL.
Tumult. Three inch diameter voice coil, XBL2 motor, 34mm one way Xmax. 12", 15", 18" sizes, dual 4s and dual 2s. Top of the line in output, great SQ. Like the current Tumults, just more options.
That's the starting lineup. And I'll post more details when it's appropriate, so no begging...
Dan Wiggins
Adire Audio
NG
Thats still quite a bit, and remember.... Xmax isnt everything
Xmax is pretty much everything for linear displacement (that along with cone area). And it's only 26mm now, down from the current 29mm. Big difference? No. But's it's still technically a downgrade either way.
However, an 18" Tumult is going to be freaking insane //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
hdave
hdave
Toronto, Canada
LoudCrownVic
