Background: what I have is 4 Infinity 5.25" speakers said to handle 45w RMS and 2 Infinity 12" subs 4ohm SVC said to handle 300w RMS. These are being powerd off the headunit for the speakers and the subs from a Jensen 4 channel amp feeding them a claimed 150w each. The amp is wired with 4awg from a cheap Scosche made Wally world kit, 40amp blade style fuse.
Planned: I would like to add an amp most likely this http://www.crutchfield.com/S-yYpu2I0fmaI/cgi-bin/ProdView.asp?g=120&I=489AP2000
Or something comparable I can get my hands on for cheap //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif and then swap my Jensen amp onto the door speakers giving them 50 watts each RMS.
Question: I have extra 4gauge laying around and I would like to do this with buying as few things as possible. However I'm sure I will need to upgrade the fuse and fuseholder but What size fuse should I run? Should it be 100amp to match the fuses in the Profile amp, or should it be a combination of the 2 amps fuses, 140amp? I know its not a big system compared to what everyone else seems to be running but will I need to upgrade to 1/0 guage or will the 4 guage handle this? I guess I could always make 2 runs of 4 gauge too, if that would be recommended versus putting the entire load on one run.
Looking for suggestions and maybe a lead on a cheap 300x2 @4ohm amp //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
