Sold Adcom, Kenwood, Rf, Infinity
buildmeabox
Other projects are forcing my to clean out the garage. Up for sale are two Adcom balanced amps, one Kenwood amp, two RF 10" subs and one Infinity 10" sub.
Adcom GFA-5275 $150
4ohms 75x2 .075%THD
2ohms 150x2 .075%THD
4ohms 300x1 .075%THD
Adcom GFA-5450 $200 includes the GFI-4600
4ohms 4x50
Adcom GFI-4600
RCA to XLR type balanced converter with a 4 channel 2 way asymmetrical x-over and two GFX-20 XLR cables.
Even though Adcom amps are capable of driving very low impedances, it is recommended that the configurations not be lower than 1ohm stereo or 2ohm mono
GFA-5275
GFA-5450
Kenwood KAC-929 $90
4ohms 150x2 .08%THD
4ohms 460x1 .08%THD
Power, Versatility, and Reliability. Two-channel power amplifiers such as the 150-watt x 2-channel KAC-929 2-Channel Power Amplifier are hard to beat. The bridged rating of this amp is 460 watts and the maximum output rating is 1000 watts. Included features are tri-mode operation, a variable low-pass crossover, selectable bass boost, a dynamic expander, and 2-ohm stability. Also included are speaker level inputs, speaker relay protection circuitry, and a quiet turn-on circuit.
Rockford RFR-2210 $85 ea.
Dual 4ohm voice coil
Fs 34
Xmax 12.3mm
Power handling RMS/Peak 500/1000
Sensitivity 85 dB
Aditional info:http://www.rockfordfosgate.com/scripts/rightnow.cfg/php.exe/enduser/std_adp.php?p_faqid=863
Infinity RF-1030w $55
The 1030w 10" component subwoofer handles up to 250 watts RMS, and is designed for use in a sealed or ported box. You'll enjoy deep, full-bodied bass, thanks to its durable polypropylene cone, high-roll rubber surround, and structure-reinforcing inverted dustcap.
polypropylene cone
deep-draw I-beam basket
70-ounce magnet structure
recommended power range 50-250 watts RMS
peak power handling 1,000 watts
frequency response 25-400 Hz
sensitivity 88 dB
top mount depth: 5-9/16"
sealed box volume: 0.75 cu. ft.
ported box volume: 1.75 cu. ft.
I got the Kenwood and Infinity in a trade, reviews for both items are excellent but I don't care for infinity and I haven't bought a Kenwood product since 1994. I'm missing the balance line converter on the two channel Adcom but if you can find the XLR to RCA cable you will be able to utilize the GFI-4600 low pass outputs or use shorting plugs. Check out this site for more info. http://www.adcom.com/manuals.aspx . I e-mailed Adcom requesting info or a manual on the four channel amp but after the buyout of Adcom the car audio department was closed and not all the Literature made it out. I did get a schematic though. All Prices include Shipping in the U.S. and Hawaii. Pm me or e-mail me at kilo3081@yahoo.com. Ask questions please.
Hey buildmeabox, any chance you have an extra pair of those xlr cables for the 4600. I have a 4600 and a 4304 that I cannot use because I'm missing one of these cables. If not, any idea where i'd find em ?
buildmeabox
buildmeabox
Houston,TX.
kappa546
