Actual wiring hookups...
PaLiAcH
another question..
as far as physical wiring goes, can you literally jump the positives and negatives from voice coil to voice coil on each sub and have only one positive and negative wire coming from each sub and tie into only one box mounting cup and pull one pos and neg wire to amp???
common sense tells me that i would prob need bigger gauge wire goin from amp to cup.... am i right? or i do i have to literally run 6 positives and 6 negative wires from amp to each voice coil??
ive included a picture...
thanx!!!
pino
what gauge wire you guys think i should use? 12 ga? would that suffice to go from cup to amp? or should i use 10 all the way thru?
thanx!!
PaLiAcH
PaLiAcH
SoCal
PaLiAcH
