Accessory Wiring TROUBLE - 12volts going to 7.44 when connected *WTF*
So Im trying to wire some accesorries in my car, a few gauges, wideband 02 sensor, shiftlight etc etc
At first I was trying to run a power dist block straight fomr the battery with a switch inline, that didnt work because of a problem just like this one
Heres my problem
Im testing this now on my CONSTANT POWER radio wire (connected to radio I jjust tapped in), I check it with my multimeter and it says 12.68 or whatever, as soon as I touch that wire with the power wire from any of the gauges to try and light them up the power drops to 7.44
I figured I had them grounded ****ty, so I gave every gauge its own ground on the center console skeleton, still no dice.
Whats causing this?
ive tapped into it before though
I dunno why my voltage drops to zero when I connect it to my power dist block that is run directly form the battery, to an inline fuse to a switch and then to the gagues, why would the power in that line drop to zero when i touch it with any of these gauges?
W O T
Banned
W O T
Milton, Ontario
W O T
