maylar
Electrical Weenie
This may be a key. You said the popping doesn't change with engine speed, and it goes away if you unplug the RCAs from the amp. My logic says that the cables are picking up something electrical, but what that could be is a mystery. Especially if it's only there with the engine running. Hmmm...Does anyone have any experience replacing/fixing the pico fuse on DOUBLE DIN / AVH models specifically? All the online guides are for the single din models that I can find. As I said above I sit here with my disassembled head unit only to not be ale to find a pico fuse
As well my rca outs are/have been grounded with all these problems still occurring. I have seemingly got rid of the altenator noise but the same snap crackle pop plagues me
Here's an idea, since you seem to be at the end of your rope - A Google of American Legacy 4 channel amps says you should have speaker level inputs. You could eliminate the RCA cables completely (and the associated ground loop issues) by feeding the amp with speaker level signals. Contrary to popular belief the SQ difference is negligible, and the low impedance of speaker lines is much less susceptable to noise pickup than RCA lines. Give it a shot.
