About when will a 6.5 speaker in a door roll off?
Yes, you have midbass and midrange and the TS parameters of all out there.
And when you say roll off.. at what slope?
Too many variables.
Ok well I guess my problem is that my Hertz 1650.3 when running full rolloff at 90 hertz, my door is sealed good, but they won't play lower than 90 hertz, is the normal? that is what I'm trying to figure out.
Crossover? I had them running full range when I checked with rew.
Run it full range. do a measurement with the mic directly in front of the speaker 6-8in. This will give you a measurement of what your speaker is actually playing and the effect that your enclosure is having.
Then when you record a measurement at your ear. Thats the effect that the reflections are having. I have some tm65s and they roll off rediculously early.
huge LMB roll off - Car Audio | DiyMobileAudio.com | Car Stereo Forum
http://imgur.com/a/YmjK2
looks like a typical cross over reduction. check the cross over box and make sure you are running the mid on the widest band available and double check you amp and head unit so that they are set to 60hz hpf min.
most door speakers when installed in properly treated doors are capable of playing down to a minimum of 80hz i usually run mine down to 63hz. but the main contributor to the ability to play down in range is the hpf and then the install.
yes some speakers dont like playing down low but thats rarely the case
That's normally. That's why we use subwoofers for sub bass
So why then do people talk about crossing them at 63 hertz, I don't really like having to run my sub up to 80-90 hertz to match.
There is very little bass and it sounds pretty bad imo from my door speakers.
awdtalon21
awdtalon21
United States
awdtalon21
