? About PDX 4.150
SRim23
So im about to install my pdx 4.150 but the part in the manual about how to set the INPUT CHANNEL is a little like chinese. i think i understand but i wanna make sure.
If i just want to run this amp as a 2 channel, without bridging, just running it as a 2 channel, which setting should i set this? heres what the manual says
" Input Channel Selector Switch
a) Setting this switch to “1 + 3/ 2 + 4” will sum
the CH-1 and CH-3 input and send it to
CH-3 while the CH-2 and CH-4 inputs are
summed and sent to CH-4.
b) Set this switch to “3/4” to have the inputs of
CH-3/4 accept independent input signals.
An example of this application would be
the use of a head unit with dual pre-amp
outputs.
c) Setting this switch to “1/2” will send the signal
at the inputs of CH-1/2 to CH-3/4 of the
PDX-4.150. This eliminates the need for
“Y”-adaptors when using a head unit with
a single pair of pre-amp output.
i think its B but i could be wrong.......
SRim23
SRim23
OH
dipitydoo
