This was a post from someone on Termpro back in 1999 and what I based mine on. Its pretty basic but it seems to work well.
Quote from screenname Buzz:
" Build a box with 2 chambers, one at 3 cuft and the other one EXACTLY half of that, ie 1.5 cuft. Next cut 3 ports all IDENTICAL in length. Put one in the face of each chamber and the third in the wall separating the two chambers. In this instance each port would be either 12.5" long for a little deeper response or 8" long for a little more SPL.(these numbers were based on a certain 15" sub, you'll need to figure box size and port length for your application)
Now you have a box with a big chamber with a vent in it, a small chamber with a vent in it, and a third vent in the wall between the two. The woofer also mounts in the large chamber.
The way they work is that, at low frequencies, it all functions as one big box with 2 ports, and is tuned to 30Hz (12.5") or 35HZ (8"). At higher frequencies the middle port starts to restrict air movement and the second chamber begins to act more as a resonance chamber but not as part of the box. At this point a second tuning frequency develops 1.9 times (almost an octave) higher than the lower one , ie. either at 57Hz (12.5") or 67Hz (8").
This is similar to a vented bandpass but has more output and smoother sound due to the woofer not being tucked inside the box. The results are that it plays both low and loud, while being relatively nice sounding. The drawback is the box size."
My design uses 3 4" PSP Aeroports (internal) and has a removable top in case I decide to change tuning (you have to be able to get to the port that goes between the two chambers).
