abc boxes
When built right ( Accurate )... They can be WONDERS. If inaccurate on calculates... They can be either: Waste of time, money, & effort... Or what you call it... a " Half box "
" Half box " - meaning only dominate on 1 side ( Low end or High end ) of the Hz scale.
Ex:
... Hits the lows it's tuned @ 28.... or Hits the highs like it's tuned @ 47 - 56
A quick summary I found:
Build a box with 2 chambers, one at 3 cuft and the other one EXACTLY half of that, ie 1.5 cuft. Next cut 3 ports all IDENTICAL in length. Put one in the face of each chamber and the third in the wall separating the two chambers. In this instance each port would be either 12.5" long for a little deeper response or 8" long for a little more SPL.
Now you have a box with a big chamber with a vent in it, a small chamber with a vent in it, and a third vent in the wall between the two. The woofer also mounts in the large chamber.
The way they work is that, at low frequencies, it all functions as one big box with 2 ports, and is tuned to 30Hz (12.5") or 35HZ (8"). At higher frequencies the middle port starts to restrict air movement and the second chamber begins to act more as a resonance chamber but not as part of the box. At this point a second tuning frequency develops 1.9 times (almost an octave) higher than the lower one , ie. either at 57Hz (12.5") or 67Hz (8").
This is similar to a vented bandpass but has more output and smoother sound due to the woofer not being tucked inside the box. The results are that it plays both low and loud, while being relatively nice sounding. The drawback is the box size.
so in theory, with a box like this could u throw more power on a sub....?, because it reduces cone excursion or .....
Yes, in theory, but it also reduces efficiency, so if you're thinking that dual chamber reflex = more power = more output then that is not correct. Dual chamber boxes will have greater box losses than a simple ported box.
This type of design isn't really about lots of power on big subs but rather, for example, preventing overexcursion of full range driver with 1 mm xmax.
all_state_34
all_state_34
hope, AR
BrianChia
