Crownvicon28s
God 1st
Probably need more power than either can provide but these are within my budget. Will be powering a sundown Z v3 at 1 ohm. Which would you pick?
The 150 will do a tad more than the aq at 1 ohm but not enough to notice ..id go with whichever u can get cheaper ..id say u can get a new aq for the price of a used 150Probably need more power than either can provide but these are within my budget. Will be powering a sundown Z v3 at 1 ohm. Which would you pick?
I honestly wouldn't by either if you are pretty sure they both wont be enough power. Cause most people's setup usually just get bigger and bigger. If its not enough power now, then it definitely wont be enough later. Look around for used equipment or save for just a little longer.............. just my 2 centsProbably need more power than either can provide but these are within my budget. Will be powering a sundown Z v3 at 1 ohm. Which would you pick?
Makes since but I gotta get rid of the audiopipe.I honestly wouldn't by either if you are pretty sure they both wont be enough power. Cause most people's setup usually just get bigger and bigger. If its not enough power now, then it definitely wont be enough later. Look around for used equipment or save for just a little longer.............. just my 2 cents
buy used man.Probably need more power than either can provide but these are within my budget. Will be powering a sundown Z v3 at 1 ohm. Which would you pick?
