AA Poly 6.5
yea sure you can purchase those mids but tweets would be nice as well. also, if you buy those mids and seperate tweets then you need either a custom built passive xover or by an active crossover.
but from your HU it doesn't have an active xover so what i suggest is you start searching on components that already have passive xovers for you to use and then amp them up. Your HU WILL NOT put 50 x 4. more likely 10-15 x 4.
but what you really need is amped tweets...
most sets of tweets don't need that much power. actually 10-15 watts to a tweeter is actually plenty. a friend of mine was running a set of lpg 25nfa ( 8 ohm tweets) off of HU power so the tweets were roughly getting 6-10 watts and it was plenty loud.
depending on the budget there are hundreds of different component sets to look at. And if that Civic there is so many options. You should have 6.5 in the front and 6x9 in the rear and they make kicks too. You could do a nice 3way setup up front with the larger woofer in the door playing midbass only, the smaller woofer in the kick(mod the kick too or get an IB speaker like the Hybrid Audio Legatia L3) and the tweet can go where ever. A good 3way component setup can give awesome results for you.
fakename
fakename
earth
alteraudiousa
