AA Mayhem or BTL
Mayhem, BTL, other
  • AA Mayhem
    Votes: 8 27.6%
  • BTL
    Votes: 12 41.4%
  • other (list it)
    Votes: 9 31.0%
  • Total voters
    29
You seem to have a very specific criteria for the sub, yet seem reluctant to tell us your goals for this setup. High BL is only critical in certain applications, a daily beater generally not being one of them. So maybe you need to provide more info if you expect better answers.
I thought i described what specs I am after and that would interpret the sub I'm wanting. You can't just tell someone, " I want the loudest, lowest, hardest hitting beat there iz foo!". Not everyones apps are the same and will perform differently.
Also stating that high BL is not a criteria for a daily beater. That's got to be false. If you have 2 of the same drivers and the same enclosure. One driver has half the BL as the other one, there's no way you can honestly say they will sound the same.
So you like the sound of BL? What does BL sound like? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif High BL is important in SPL setups that burp at or very near tuning, as the high motor force helps overcome the damping effect playing very near tuning has on cone motion. But for a daily driver who is playing freqs all over the place, Id rather have a consistent BL force than simply a high one.
You have described what specs you are after, you just haven't described why, or what type of system you are after. If you just want this, this, and this spec met... its a simple matter of doing some of your own leg work to look up specs. We cant really offer any opinions here on final performance, all you are asking us to do in essence is help with your leg work.
I hope your list of specs works out to sounding the way you think it will. Cheers.
Precisely.
Specs on paper aren't everything. That is what I'm getting at...
That's why some manufacturers don't even list T/S parameters, because some guys look into them a bit too much. They are only indicative of how a driver may perform under certain conditions, or indicative of general performance...
nG
TnT_Sounds
profiling gets **** done!
TnT_Sounds
Colorado
IgnoreMe
vegang
vegang
