A8001DT AudioBahn Amp Problem Help Please ....
I'll try to make this not harsh. Your amp is probably blown. You should replace it with a non Audiobahn one.
That amp is actually decent...def overpriced but decent none the less. Audiobahn used to make good quality amps, they do not make good quality amps anymore but some of them like this model are decent. It is even 1ohm stable most stats don't show that, it will pump out close to 1k at 1ohm
before playing music, check to see if dc voltage is coming out of the speaker terminals. if so, (other than real small amounts, like less than 1vdc,) then don't play it. that would mean bad output transistors, and that could also damage the drivers for them, and even the power supply section, if you keep playing it. (makes the repair a little less simple for someone to do)
FYI.. These are not a Car shaking sub.. But these will give you some pretty nice bass in almost any vehicle that has nothing at all. Best placed...
80
  • Locked
262
Amp
283
xxwickidbaixx
xxwickidbaixx
Ocala, FL
akheathen
    May 16, 2024
    May 16, 2024
