A fuse can't destroy an amp, see the amp would have to draw a lot of power to pop a 250 amp fuse. The problem is that the amp you have usually does not draw that much power, so basically your amp messed up and started drawing way to much power which in turn popped the fuse. Your amp is most likely broken, it may still power on but it probably won't work unless someone fixes it.
