A noob question, I know...
IDSkoT
Resonating Reticular
But I feel a need to ask it...
Let's say the sub is on the right side, will this make an unbalance of bass through out the car? I mean, I see a lot of set-ups where a single sub is off to the side. But, I was just wondering if that made an audible / SQ variables.
Move it around and see. That's really the only way to tell.
My guess is that you won't see much of a difference. The direction you fire the subs and how far back you place them will make a much bigger difference.
The problem with that is that I have a really small trunk [i have a '98 Mustang Coupe... and let's just say I have 2-10"s in .75 cubed dual-chambered box, and I had a tough time getting that into my trunk...
And I don't really have my own tools, so whenever I build a box it's at a friend's house-- and it's not like I can just be like "This is a test box..."
build a box and try it as many different ways possible but prolly sub back port back would be best
That's what I was gunna do. And then put the amps on the side with the sub centered in the middle.
I might not port it... on the Fi forums on SSA they basically said that sealed sounded better. But I'll try both.
BTW-- is that an S14 in your sig?! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I want an S14 so bad-- but there's none in good condition down here in Miami.
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
IDSkoT
IDSkoT
Miami, Florida
IDSkoT
