Ill beleive it when a reliable source tests one. If it does put out rated power I cant see daily beating on such a small amp with such low fusingHello! 12,6Vdc power RMS ratings.
I was thinking the same thing, but I'm still learning about efficiency. Isn't it like 10 amps per 100 watts or something like that?Hows that going to make 1800 watt RMS with an 80 amp fuse?
thats a general rule, but nothing concreteI was thinking the same thing, but I'm still learning about efficiency. Isn't it like 10 amps per 100 watts or something like that?
1608 Kinda wish I got the 2008dIt would actually be 14.4 X 140 X .8 = 1612
But you got the right idea... Do you have the bxi1606?
haha send one to meWould be very nice if some good member of the forum test the amp...
These are MAXI fuses, they support 5x the normal current rate for current peaks with less than 5s.the fusing scares me, the size doesnt.
So if you burp longer than 5s the fuse is going to blow?These are MAXI fuses, they support 5x the normal current rate for current peaks with less than 5s.
During the normal play the power compression phenomenon + high crest factor f the music signal makes the average current flow be about 40-50% of the maximum, at the full power.
Depends, depending on the woofers used the Re of the coils would rise and the fuse wouldn´t blow.So if you burp longer than 5s the fuse is going to blow?
