98 Mercury Sable HU prob?
1stAugie
Is anyone familar with the stock HU for the 98 Mercury Sable, Here is the Prob with my wifes car: The radio does not pick up any stations,I have pulled the HU to make sure that the antenna is connected only to find that it does not have a standard coax cable,nor is there any spot for it? Do to the design of the system I cant just simply replace it with a after market HU. The Sables have all the Climate controls connected with the unit??? Any help with this problem would be greatly appreciated!//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
With an aftermarket HU theirs a panel that replaces the whole front assembly where all the switches are so that their still their with an opening for a standard din. I'm not to sure about the antenna, but I do know that it requires an integration kit which comes with the panel. It can be found on crutchfield and various other places, it runs about 50-60 dollars or so.
Look under the trunk liner, inside the trunk on the driver's side, directly under the antenna. You'll see a silver box mounted to the inside fender; the antenna plugs into the bottom of the silver box.
Yep - as is all the other wiring associated with the factory radio - power, ground, speaker wires, etc.
A true PITA for anyone wanting a better than factory stereo in a late-model Sable or Taurus //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
1stAugie
1stAugie
Alabama
Prowler573
