97 Escort - Need tips to reduce rattle
The use of dynamat and other sound deadening material will help in the reduction of rattle in your vehicle. It all depends on how much of it you will use, and if it is in the right spots. I would recommend the use of dynanmat extreme. It dampens extremely well. And in the hard to reach areas use the spray. Using this will keep the sound inside the vehicle, and not outside the car.
I agree with what he said and also try to tighten everything down as tight as you can to help stop the rattles. Remember that the more you rattle the more bass gets taken away so good luck.
another product i saw this weekend at the car show works really good for the license plate, it was the dynamat license plate kit, but more or less all it has is a piece of extreme for the back of your plate and then a dynamte frame for the plate, but it was only 15 bucks so it was worth it to stop the plate from vibrating and rattling.
97EscortBoom
97EscortBoom
Front Royal, Virginia
EPanther99
TechGuru88
    Aug 10, 2026
TechGuru88
    Aug 10, 2026
