9515rob Wall Rebuild
did some work tonight on leveling the top and some of the back. I made one hell of a mess with the hand plainer
Just a little bit of a mess. It was hell to vacuum out
Dirty Boy hahaha
Holy wood shavings Batman!
got a hell of alot of work done on the wall today. Got the top,bottom,sides, and back covered in mdf. All i got to do is 45 the corners and then its time to do some glassing
i will get pictures of it tomorrow it was to dark when i finished up today
Got some work done today
Here is how it looked yesterday
Did some glassing tonight. I am going to have to do alot of sanding because i make one hell of a mess
Kyle thought he would be funny with my old DD sign i made
Here is what 10s i plan on running in my final set up. A guy that owns a shop north of me and that i compete with has his own sub line he gets made. his sub line is called Rival Audio
These 10s if i remember right are 1500rms
well i figured i would finish off my first gallon of resin so i fiberglassed one of the corners and then put 20oz of resin on the floor
Im kind of pissed because where the heat lamp was it made the resign bubble up so its not smooth like how it should be.
Will get more pictures of the corner in a little photobucket doesnt want to upload my pictures from my phone for some reason
These look like some beasts, how much does it let them go for?
i dont quite know what the price he is selling them for. I am getting a special price
They wont be out till august or the end of July
---------- Post added at 11:18 PM ---------- Previous post was at 11:18 PM ----------
Any T/S specs on them puppies?
They arent out yet so i couldnt tell yah they are still in the process of being produced
i might want some 12s
send me a pm of what you are looking for power wise and i will see what i can do for you. He is working on getting alot of his line produced since it is a new company. If you are looking for a huge 12 he has a 4" coil line that i know is some bad assssss shittttt
well i got tired of glassing so i called it quits on that and figured i would move on and do some bondo work. This is my first time using kitty hair and it *****. I didnt think it would be that big of a b1tch to work with
Started working on a the first corner and made one hell of a mess.
well i did a quick sand to get all the high spots down and threw another lay on top to smooth it all off
i got less than a 1/4 of a can left. I dont think im gonna bother with the top of the box since i havent made to big of a mess up there glassing so its pretty smooth and i know its nice and solid from the 2x4s behind it
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
884
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
9515ROB
TEAM DTF
9515ROB
Sherman IL
9515ROB
    May 16, 2024
    May 16, 2024
