9515rob Wall Rebuild
9515ROB
TEAM DTF
2,385
Sherman IL
Well since my subs are off getting fixed and my amp is sold i figured i would rip my wall out and batts out. The other reason was because it isnt a busy year for comps and have alot of time before the next show
Im building this one in the car unlike my other wall. Also i am trying to do a drivers side port.
This piece was on top of the batts it was my temp amp rack
3 screws in i took a chunk out of my finger
Looks like one hell of a mess doesnt it
Some of the mess is gone
Hard to believe that all fit in a trunk of a mustang isnt it
Time to start taking out the seats and center console to take the box out
The wall is out. Kinda fucked up my headliner and was hoping to keep the box how it was when it went in but it didnt happen o well
My cars suspension was bottomed out it was sitting at 25". I gained 2" of it back from just taking the batteries out and another 1" from taking the wall out. It is nice driving with all that weight out it is back to being some what quick and i can roast the tires taking off again
Well i thought building a wall in a car would be a little bit easier than what it was. I started by trying to make the floor and that was an EPIC fail. So i screwed a board to the back wall and went from there.
The first load of supplies
Have you guys heard of the new pick up truck Ford came out with? Its called the Ford Mustang
So i started working with the top since i figured which way i should do it first. This is the top bracing
I will be adding more 2x4s across them i have to have room to screw them in from the back side so i had to hold off
The small part will be the top going to the front of the box and the longer pieces are going along the back window
Thats all i have got done so far i need to spend some time studying peoples builds
What amp do you plan on running, or are you still deciding? Also, what subs do you have?
Im gonna be running 2 Crossfire XSv2 and i havent decied on an amp yet it will most likely be a American Bass 1100.1 but i have been looking at the DC amps a little too
well this is alot harder than i thought everything i do doesnt work so im going to give it one more shot and if i cant get something going im just gonna recover my old wall and put it back in
well everything i had done went to the scrap pile. I have had alot of trouble the first couple times i have tried to do this so i took a break for awhile and went back to work on it today.
I got alot of work done today. I got the floor, back and top in tonight along with a little bit of the side on the drivers side.
This was the only pic i got in before it got dark. It wasnt fully together there but u get the idea
Im going to have to take the hand plainer to some of the 2x4s to get them level with the other ones.
did some work tonight on leveling the top and some of the back. I made one hell of a mess with the hand plainer
Just a little bit of a mess. It was hell to vacuum out
Dirty Boy hahaha
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
859
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
9515ROB
TEAM DTF
9515ROB
Sherman IL
9515ROB
slater
    May 2, 2024
slater
    May 2, 2024
