ah, was going ask if there was a factory alarm brain to look at.got an email from vovlo a min ago saying to check for yellow/white coming out of the factory alarm harness
yeah when the dash is dropped down the factory alarm is right in your face....anywho thanks for the the input im off to bed for the evening. Ig we are slow tomorrow i will get it back in the bay and hopefully get it straightah, was going ask if there was a factory alarm brain to look at.
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif hadnt planned on making any keyless connections until all would be done.use that method when ever you need to diode isolate 2 or more wires. ( door pins, alarm wires, etc)
I'm in the exact same situation as you and have duplicated everything you've mentioned here exactly.there is no central switch. Going into the door found me only the motor wire i was unable to 5 wire. But new development....the yellow/gray wire in the kick if i cut it and turn the key in either door it will lock that door only but im able to trigger the rest of the doors with the keyless
