93F outside. Normal for amp to go into thermal protect?
JoeK
I noticed my amp cutting off after about an hour or two of constant use. Its an Audiopipe APSM-1500 and im running a 1ohm load at its limits. It goes into protect but will eventually go back into normal mode, only to go into thermal again. Its 93F outside and its in a trunk. Anywho, is this normal?
get a multimeter and check the impedence that the amp is seeing.
1.23ohms
---------- Post added at 01:40 PM ---------- Previous post was at 01:39 PM ----------
no. your clipping your amp. turn the gain down a little bit. your amp should never go into protect.
I hear no distortion, and i tuned it down further from the point that i did. The gain is less than half-way
1.23ohms
Also, the amp is real hot to the touch even.
its been 104 ehre during the day.. in my trunk its been 140degree's.. my amp goes into protect if i push it hard.. amp is turned all the way down.. no bass boast etc.. on the amp or radio.. the amp gets hot enough to cook bacon and eggs on
JoeK
JoeK
Ringtown, PA
JoeK
