9.1 and W7
Thanks for the quick replies. So the 9.1 should experience any problems? Cuz if not then I will just leave it hooked to the w7 and just get the money back for the 500/1 instead of a replacement. If not then of course I will get me a 500/1. Thanks again.
Depending on if you want the extra power or saving money, the Nine.2X actually puts out more power @3ohms than the Nine.1. The Nine.1 will put out around 650W and the Nine.2x will put out 750-800W for cheaper.
Model Name : NINe.1 Class D Amplifier
RMS Power @ 12.5v : 1200 x 1 @1ohm,900 x 1 @2Ohm,450 x 1 @4Ohm
Should be 675 watts @ 3ohms with 12.5 volts so running around 13.8 volts it will see even more power, also remember that you are not really going to get that much more out of the sub, in the right box 500-600 watts is going to push the sub to its max.
Model Name : NINe.1 Class D AmplifierRMS Power @ 12.5v : 1200 x 1 @1ohm,900 x 1 @2Ohm,450 x 1 @4Ohm
Based off of the power ratings, it'd be 600w @ 3ohm.
sqrt(450*4) = 42.42641
42.42641^2/3 = 600
ScooobyDoo11
ScooobyDoo11
FC, VA
helotaxi
