88 Bronco stereo wiring question
timstumbo
I recently bought a bronco that had the radio stolen out of it so the factory radio harness was cut off the wires. No biggie, I found a wiring diagram for my bronco online and I figured I would just hard wire the new stereo in. I have identified almost all the wires, but I had one question. The Left Rear Speaker Negative Wire and the Right Rear Speaker Positive Wire are both Pink/Blue. Problem is, I only see one of these wires. Does anyone have a explanation for this? Thanks for the help!
1988 Ford Bronco Car Audio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5″ x 7″ Speakers
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6″ x 9″ Speakers
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
I have had a few fords and iirc they share a ground. I am not positive because it has been a while since I did anything with them. Should be easy enough to check.
pull the rear speakers and visually verify. use a DMM to trace them or measure resistance.
if they are sharing a ground, then the pink/blue is positive and green/orange is the shared ground. but a modern head unit cannot share a ground since each wire is hot.
i would just re-wire the speakers. it's not that much work.
I figured it out. I pulled the rear speakers as suggested and was able to identify he correct wires. Should have done that before. FYI though, that wiring diagram was incorrect!
This is scary, my first truck was an 89 bronco green with tan top, the first thing i did installing my first system was cut the little wiring blocks off thinking that the cd player directly wired to them, boy was i wrong i had to use snow caps and tape each one back once i figured out it came with a wiring harness.. this is wierd
timstumbo
timstumbo
Greenwood, SC
brown7348
