800watt mono amp?
like you need 800wrms @4ohm, or you have 2 4ohmdvc subs(possible 1ohm load) and need 800wrms
Which amp will power my two 400rms sub woofers which have dual voice coils and 4ohm impedance?
Want to spend about $100 dollars if possible $150max.
Thanks.
That all depends on your amp. My AB would give them 450 watts each 2 ohm stereo. Your enclosure will also make a difference.
I'm almost sure I want to wire them @ 1ohm, so I need an efficient 800 watt 1 ch amp, but which one?
The reason I'm going with 800 watts is because I might find a less expensive one brand new, than a 1000.
It's going to be hard to find a 1 ohm stable amp, that has good quality for that kind of money and puts out that kind of power. I wish you luck.
Doesn't need to be good quality, I just need something avarge that will get them pumping out some bass at their suggested rms, there has to be a decent amp that put out 800 watts for $150, isn't there?
MyPoison1
Why?
MyPoison1
Los Angeles,CA
CamryMTX
