8" & 6.5 in door- what brands to use?
i'd say go with dayton because they have select 4ohm models
if you have the power to use an 8 ohm driver, you have lots more options
aurum cantus has a dual-8 ohm model if you wanted to slip into a 10"
I have heard the kicker ssmb8's and they sounded very nice //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
That's what I use, and I like them a lot....really shallow also.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Dayton 8" woofer, I would reccomend a DD W6.5 but it would most likely overpower the Dayton, Scanspeak 4" revelator mid, and then whatever for a tweeter. Great DIY setup.
i doubt with the right power that dayton wont keep up with the DD. also i love the revelator but you need more than a "whatever tweet" for that set-up.
Yes I know on the tweeter. I just said whatever tweeter because I don't know how well he could decifer between tweeters.
The dayton might keep up with the DD but that little 6.5 is known for being a beast.
I was thinking of using Alpine X and a decent 8" mid, I got subs in back... SQL setup
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I wouldn't use a 6.5" comp set with an 8". Waste of space and money. You could easily get away with a cheaper 4" comp set or DIY 4" (or smaller, like 2" dome) and tweeter with an 8" midbass driver.
Much easier to install and cheaper on the wallet.
davidtemple
Caraudio Guru
davidtemple
Louisville, KY
squeak9798
