he just wanted to know what the final load was going to be. if he wanted to ask if he was suppose to wire a 15" woofer with a tweeter then your post would be helpful. just give him the final load and leave it at that.
>>But if i wire them together in parallel, what ohm load does it give?
The post says that both woofer and tweeter are wired in parallel //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
This is not how you hook up tweeters.
If a tweeter crossover is used, then the final impedance won't be 2.6 ohms
because impedance various with frequency. At high frequency, the amplifier
may see a 4 ohm load, at low frequency, the amp may see an 8 ohm load,
it's a variable.
How do you think a common loudspeaker with an 8 ohm tweeter,
8 ohm midrange, 8 ohm woofer, three drivers in a cabinet, yield
an 8 ohm impedance ? It's not considered a 2.6 ohm impedance loudspeaker
as each driver has it's own bandpass region.
