Sold 785 shipped for everything left
is that am zenon board? does it do rated and at what voltage?
no zenon but it is korean like ab and dd among others
RMS @ 4 Ohm: 700-1000 x 1 Ch.
RMS @ 2 Ohm: 1300-1800 x 1 Ch.
RMS @ 1 Ohm: 2500-3000 x 1 Ch. very underrated at 12-14v
RMS @ 1 Ohm: 4000W x 1 Ch @18v
Signal to Noise Ratio: >100dB
THD (IHF-A): 0.2%
Input Sensitivity: 0.15V – 5V
Input Impedance: 47KOhm
Slew Rate: 10V/USec
Damping Factor: 300 @ 4 Ohm
Fuse Rating: EXTERNAL 200A Fuse
Dimensions (in mm):
Width: 240mm
Height: 61mm
Length: 570mm Features
MOSFET Power Supply Amplifier.
Double Sided Through Hole Epoxy PCB.
Gold-plated Brass Set Screw Terminals.
24dB/Oct. Crossover - Variable Low Pass Crossover (40Hz ~ 200Hz)
Variable 24dB/Oct. Subsonic Filter 10Hz ~ 70Hz
Variable Phase Shift
5 Way Protections
Daisy Chain Through Output RCA
Bass Remote Control
Power/Protection LED
1 Ohm Stable Circuits
Soft Start/Output Relay
18V Operation
Parallel Operation
THD (IHF-A): 0.2%
Slew Rate: 10V/USec
Dimensions (in mm):
Width: 240mm
Height: 61mm
5 Way Protections
Bass Remote Control
18V Operation
Parallel Operation
//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
infamous_e46
