700 rms too much for Kicker cvr 12"?
if you have two then why not hook them both up that way each is getting around 350?
Because they are Dual 4-Ohm so I would need to wire them to 4-ohm or 1- ohm and the amp is not 1 ohm stable. Which leaves me only able to use 1 sub with that amp wired to 2-ohms..which is why i asked if 700 rms was too much for just one.
If anyone knows if this is possible i'd appreciate it, I just hooked the amp up to 1 sub and it bangs but sometimes the soing will cut out for a few seconds..is this because it being given too much power?
Newff
Newff
Fort McMurray, Alberta
Bass Addict
