$70 deep cycle battery
What do you like best.
  • Total voters
Good, I figured that. If any one has time, maybe they can post a diagram on how it should be wired. Typical set up. one bat in the engine compartment, O gauge from bat to fuse, then to distribution block then to three amps grounded to the frame. I need to know where to put the bat and how to tie it in.
Just run the pos. wire from the battery in the front to the pos. post of the battery in the rear.Ground the rear battery to the frame.You can use the pos. post as a point to attach you distrubution block.Ground amps to the frame or battery.
oh really.... Fck then, this will be a peice of cake.
i never really messed with multiple batteried system when I used to install for work. Other guys usually jumped in to help with the set up and I just focused on the other stuff.
subzero
subzero
Chandler, AZ
audioarsonal
