7" motor
ohh no called 25mm+ total //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
---------- Post added at 04:26 PM ---------- Previous post was at 04:25 PM ----------
each way
A couple motors here for ya if you're interested.
These MTX Thunder 8000's are in very very good condition, and were used by a mature adult. The only thing that was wrong with them when I got them was one tinsel lead on each sub was broken off at the cone. The voice coils are in pristine condition, aesthetically nice with no discoloration or signs of wear. These 3 subs were not blown or abused I only mention this because there will be no caked on melted glue residues on the inside of the gap to deal with.
This JL W6V1 is definitely a few years old. The Top plate ID should probably be turned approx. 0.5mm just to even out it's surface ( I would at least ) And as you know these W6's used rivets as opposed to a screw/nut configuration for basket attachment. The rivets have been ground down just enough for basket removal and may still be used as an allignment point in conjunction with glue. Or you can grind them off completely and attach a basket however you see fit. The motor will also come with the rubber slug guard that comes standard on the old W6's.
My pricing is negotiable on these. Send me a private message if you are interested.
Thanks,
-Steve
SPLaudio
SPLaudio
upstate ny
SPLaudio
vegang
vegang
