6x9s or 5 1/4s
fatboyracing
ok I have a new accord has 6.5s in the front and 6x9 in rear. I have a set of 6.5 and 5.25 comps, I am for sure using the 6.5s should I get some good 6x9s or go with the 5.25s in the rear.
And I want rear fill... Kids in a back seat all the time
Oh ya the comps Ihave are low end cdts and everything will be amped
I've heard that alot before too, but have also been cused out for sayiing it before as well so maybe someone can clear it up for us
It was specified in CA&E.
Basically, imagine when the speaker emits sound, the cone is going faster on the two sides closer to the center, and the two sides further from the center have to "keep up" in the process. A round speaker moves as one, whereas an oval, well, can't.
humm...I dont quite understand your arguement but I did find this
http://forums.trinituner.com/forums/archive/oval-versus-round-speakers-38695.htm
the round cone tends to be more study at highe excursions and is less likely to warp as the strenght is even right around the oval willtend to warp quicker as there are pts of different strenghts in the structure of the cone
then this:
Round Speakers VS Oval SpeakersThe subject goes as follows: A 5.25" speaker can fit in a stock 5x7" location, and a 6"-6.5" speaker can fit in a stock 6x9" location. So which should you use? It's quite simple. A round speaker is more likely to have weight evenly distributed against the Voice Coil and VC Former. This means that you can achieve clearer sound with a round speaker that with an oval speaker. On the flipside, an oval speaker will obviously have more cone area. With the same excursion as the round speaker, the larger oval cone produces more sound. An oval speaker is capable of getting louder and usually producing more mibbass than a round speaker.
There are a great many exceptions, more and more as the quality of your speakers goes up, but this is the general overview.
fatboyracing
fatboyracing
Owensboro KY
P.T.R.
BP1Fanatic
BP1Fanatic
