6X9s not working correctly
  • 2
ga_boi
I have a pair of eclipse 6X9s in my car that keeps goin very low on me but they come back in when iturn the volume up really loud and then they will play regularly, but it keeps doin this on me could i get some suggestions on what to do do fix the problem. i have them running on a RF500s amp and one more thing i didnt start having this problem ubtil i took my subs out of the car. thanks
You could check your RCA connections to see if one is loose. Recheck the speaker leads to the amp and make sure they are not touching each other or anything else.
What kind of HU?
Figured it out. For some reason my rca cables would work in everything but the new head unit. I quickly tried a spare set, and that fixed the problem.
There isn't much it can be. Pull the amp turn on wire out of the amp, and just run a wire from there and touch the distro block will activate...
6
Its lasted 19 years thus far. Could be something as simple as a wiring connection as stated. Nothing in electronics last forever. Its had a great...
8
ga_boi
ga_boi
Hazlehurst Ga
ga_boi
vlusardi
    Apr 27, 2024
winkychevelle
    Apr 27, 2024
Latest topics
