6x9's @ 175w rms
edit: but they handle 900watts;)
Right....900 Boss Amplifier watts!! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
If anyone's wondering, these will be for rear fill.. but they need to take 175w because they'll be fed off of a kicker 850.4.. and I need to them to 'decently' keep up with the germs.
175w each
I've just done some looking and I cannot find anything that is designed to handle that much.....Are 6 x 9's your ONLY option??? You can always modify the mounting to fit some components that are designed to handle more wattage and will sound better too....
There is 1 thing you will need to consider....This is coming from "personal" experience....If you have your rear fill exposed to the pressure from your subs in the trunk, you'll very easily blow them due to the excursion they will experience. If you still decide to install some rear fill, you'll need to have them in their own air space.....AND I happen to own a Buick too, I've just got the more luxurious model //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I thought about modifying.. but I'd rather just use the factory holes. I'll probably wind up having to modify, but I figured I'd ask first.
The subs won't be in the trunk //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I removed the backseat, and they're going back there. Trunk will be for amps and such.
djvi0lent
djvi0lent
Southeast Texas
Louisiana_CRX
