6w0's for dedicated misbass...? check out the T/S specs.....
BassAddictJ
from what i've read up the jl 6w0's are geared more towards being a small subwoofer than a midbass (fs of about 37hz). in a small sealed enclosure people arent recommending anything overlike 150hz...i would want to run mine in a small sealed (probably slightly smaller than recommended specs) from 80hz to 400hz....judging by the t/s specs would this be a bad idea?
6w0 data:
http://mobile.jlaudio.com/pdfs/6_8W0_MAN_pages.pdf
I have never heard them being run that high. These were truly like small subs and the systems I have seen them a mid of some type picked up using at 100 or so. You could try it, but I think the top end might get a little dirty. Unless you already have them or are getting them super cheap, I would try more of a true midbass.
You need to find the inductance and there is a formula to use to calculate recommended high frequency extension of a driver. I believe I have a specific web site bookmarked that has it. If JL doesn't list its inductance, call and ask them, or measure it yourself. Otherwise, it's a shot in the dark and it will be up to your ears.
You also need to know the direct-current resistance. The formula to find the highest frequency it can theoretically reach before it starts to roll off (at 6db/octave) is...
Re / 2*π*Le
where Re is resistance in ohms and Le is inductance in Henries.
Re / 2*π*Le
im pretty sure they were both right at 3.6ohm. ill double check...i think i might as well do some math before i part them out. rather see it on paper before i start moving speakers around...
Re / 2*π*Le
im retarded...what variable is "n" again? number of turns?
BassAddictJ
BassAddictJ
FL
BassAddictJ
