6 channel amp? or 2 amps?
wolf55
hey im runnin 2 6" infinity reference components in the front (bout 50 rms) and 2 6*9's in the back (bout the same rms)... and i am getting 2 15" spaeakers rated at 200 rms each...
i want an amp to power at least the front speakers and the 2 fifteens... i dont relly need to power the 6*9's..... should i go with a 6 channel amp? and if so can u recommend one...
or do i need 2 amps?
thanks
it will be hard to find an amp that will bridge to allow for 400 RMS plus for the 15's and still be able to power the fronts with 50+ RMS i would suggest 2 amps something small and moderate for the fronts and 6*9 and a smaller 400 for the subs assuming you have the availible prepouts on ur headunit i run an alpine mrp-f250 for those same infinity speakers and a V12-605 alpine for 2 10's it sounds good amps are about 200 a piece. so that not that bad any 6 channel will run you atleast 500
those are my 2 cents
good luck
A six channel can do everything you are looking for and then some. A good one with a nice crossover built in can simplify your install and be flexible enough to change things up down the road if you want.
I too have the perfect amp for your application....
wolf55
wolf55
miami, fl
W8 a minute
