Actualy the way it is set now I get voltage in the 30's with a test tone of 1000HTZ at around 65 instead of 70 So it clips even sooner, but when I play music and not a test tone I don't hear any distortion at these levels.
I just turned up the gain on my woofers also because they sounded anemic with the Gain set acording to the tutorial. I turned it up about 1/2 way to where it sounded good, if I detect distortion I guess I can always turn it down on the HU or make adjustments by ear, as I think they are more accurate that way for the woofer, Otherwise I have to have the woofer on like 15 to get any response or make it hit all all with regular music, (Sublime, Slightly stoopid etc) and that does not make for much adjustment (turning down wise) Since it is still not very loud at 15.
I really don't understand how to adjust the woofers, I think If I do it again I will set the woofer to 10/16 and adjust the gain with a 50 Htz or 60 htz tone also at volume 60/80. The voltage drops quickly by turning up or down the woofer so I don't know where it is best to have the controll set at on the HU.
For the woofer and Hifonics @ 16/16 the test tones always make the amp clip even with the gain turned all the way down on the amp I don't know what voltage range there is for the Gain on the older Hifonics Z600 it does not show anything on the knob and I lost the manual years ago. It appears to be similar to the eclipse though.
So From what I have experience when using an amp that does not support the voltage from the pre-outs you can't exactly follow the tutorial.
The eclipse's volume controll is not linear, at about 2/3rd volume the voltage sent out by the pre-outs increases quickly. I do not think you have to have everything turned up to see 5V, in fact I think I would be seeing as much as 8V with everything turned up all the way. I think the pre-outs must be rated differently than other manufacturers but who knows how they rate them?
It appears that when setting up an amp in this way your actually just setting the gain relative to a point on the volume controll, so there fore it would probably not be a good idea to turn the volume past 70 for normal music and not past 60 for test/tones and other music that is hard on the system.
Does it sound like I am doing this right for my setup?
