SOLD 5000 watt amplifiers! LOOK!
TeamPSI
Super Pimp VIP Member
These amps are the same exact thing as the Atomic 5000.1
They came from the same buildhouse that Atomic uses for their amps as samples. They make over 5kw each and are strappable.
The heatsinks do not have any name on them at all.
* Digital mono block amplifier
* Dual MOS-FET power supplies
* Efficiency over 86%
* RMS power handling---1500w @ 4 ohms @14.4V
* RMS power handling---3000w @ 2 ohms @14.4V
* RMS power handling---5000w @ 1 ohms @14.4V
* Signal-to-noise ratio 90dB
* Phase shift 0-180 degree
* subsonic filter: 10-60Hz
* lowpass filter: 35-300Hz
* Input sensitivity: 200mV -6V
* Bass remote controller with telephone wire & click volume & blue LED
* 3 way protection: over voltage, speaker short & thermal overload
* Total harmonic distortion:
* Continuously variable 0 – 18dB Bass Boost
* Built - in variable 0 – 18dB per octave x’over
* Power Consumption
* Size: 24.50” x 10.60” x 2.60”
The amps may have some very slight scratches here and there but are in great overall condition.
They sell for over $2000 retail and around $1500 at competitor cost! My price is $750 each! I have 4 of them for sale.
wish i had more cash to get another one would make a mean install strapped.//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
5
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
TeamPSI
TeamPSI
Pink Star Industries
jk32sho
