5 Way Crossovers??
BassAddictJ
Basically I want to be able to have the crossovers abilties my 3 way active deck offers but in a single unit. I want to use my alpine 11 band EQ, but it only has 1 front input. SOOO the plan would be have the full range signal front from the EQ outs go to an external crossover unit that will give me the bandpass needed for the dedicated midbass (say 80hz and 500Hz), midrange (500hz to 4Khz ish), and highs (5khz and up).
are there any crossover units that have the HPF and LPF for the mid bass AND midrange, and HPF for the highs?
If I can achieve this I can use my half din old school 11 band EQ that i love all so much.
just use a regular 3way crossover, and on your midbass amp just use the internal crossover on the amp on high pass, and, run the lowpass signal from the crossover to it then, dont run your sub amp through the 3way crossover and just set its lowpass wherever you want
BassAddictJ
BassAddictJ
FL
jdawg
vegang
vegang
