Sold (5) RE 35.1 Imposters - Ampman Audio & Better Audio
TeamPSI
Super Pimp VIP Member
I have 5 amps total. Two of them are Ampman Audio Revolution 1500D's and three of them are Better Audio 1600M's. Both models are the same thing as the RE 35.1D amplifiers.
The Ampman Audio amplifiers have been repainted with some sort of textured black paint. They look nice, but I don't think the paint is very durable. As long as you don't beat on them they should be fine though. Neither of these two amplifiers have the set screws in the Power and Ground terminals, but they do have all of the speaker connection and remote wire set screws. These amps do not have the rear covers on them. This is no problem at all as long as you don't go poking things inside of them. : I would rate these amps 8/10 cosmetically.
The Better Audio amplifiers have all of their set screws. Two of them have rear cover plates, one doesn't. A couple of these amplifies have dents on the corners where they were dropped or something. The dents aren't terrible, but they are there. These amps are a 6-7/10 cosmetically.
All of these amps were sent to KB Audio to be tested and guaranteed to work. They have not been used since they were returned.
I will sell these amps for $250 each SHIPPED
I ran mine at .5 ohm, beat the hell out of them, and never had a problem!
But ive heard rumors of david rubbing his junk all over all the audio equipment that he sells.....so just wash them before ya use them!
which of these amps were run at .5 ohms and what amount of watts did it push?
Over time, ive had 4 different amps, 3 of the were RE audio, and one Better Audio. They are all the exact same amps (from what i can tell, david can back it up) and they were beautiful. I live in upstate NY where during the summer it gets to 100 degrees and insane amounts of humidity, and these amps ran fine in that weather, and i deffiently put them through alot of stress.
Bump for a good guy, even if he does rub his stuff all over the equipment!//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
TeamPSI
TeamPSI
Pink Star Industries
DumpinTreos
